Field Service Mobile 10.7.8 - Updated Apple Push Notification Certificates
MarkWilliford
For customers using the Field Service Mobile Client 10.7.8, the Apple Push Notification certificates used by this version of the mobile client expire at the end of December.  These certificates must be renewed annually and a patch is available with updated certificates for 2016.  Please contact the PTC technical support team to receive a patch with the updated push notification certificates.  If these certificates are not updated on your MIS servers before the current certificates expire at the end of January, then all push notifications to iOS devices will stop working for the 10.7.8 mobile client.
Note:
• An MIS only bounce is required after applying the patch.
• The patch will only contain updated APNS certificates and no other changes
• The files that are being replaced are found in this path MIS/WEB-INF/classes/ios/production-apns-cert.p12 and MIS/WEB-INF/classes/ios/development-apns-cert.p12
1 Comment
MarkWilliford
Correction to the blog:  The 10.7.8 Mobile Client Certificates expired in Dec 2015.  Please reach out to the Technical Support team to install the new certificates as soon as possible.
