Config.pro parameter for display style.
jwallis-2
2-Explorer
I'm trying to identify the config.pro parameter that sets the default display style to 'shading with edges'.
I've thus far been unable to locate the correct option. Is anybody able to assist?
(I'm using CREO 2.0, not that I believe that makes a difference)
Cheers
Jake
James62
(To:jwallis-2)
Click onto the image to make it larger.
James62
(To:jwallis-2)
jwallis-2
2-Explorer
(To:James62)
Many thanks Jakub.
Problem solved
The description of 'display' in the options list says how the settings are reflected in printing and export modes, so I didn't realise it was the on screen settings.
James62
(To:jwallis-2)
No problem. There are plenty of little things in Creo that seem little odd at first glance. Some things also seem rather hard to understand, mainly cause the software kept on updating over time. There are still some old ghosts, but you can find lots of info around here to help you out.
If not then just start a new thread.
Welcome to the boards.
