After Installing Creo 3.0, and attempting to launch Creo parametric through the shortcut created on the desktop, An error came up, saying that windows could not find the application Parametric.exe, I had a search through were it was installed and couldn't find it either.
I have re-installed it twice and reconfigured it once, to no avail.
Any help is much appreciated.
Look at this thread to see if it helps.
Re: I completely installed Creo but I do not know where to access it or open it?
Also you might want to post to and/or email academic support:
Lawrence,
what operating system is installed on your PC ? FYI ... Windows XP is not supported.
MH
