To whom this may concern,
I have a problem with Creo 2 simulation for a very long time and it worsens as time goes by. I hope that somebody can help me to solve it.
Symptem:
Creo 2 Simulation crashes while exporting result window to bmp files.
Error Message on the traceback:log:
The trace creation timestamp is: Thu Jun 04 09:29:53 15
The executable build timestamp is: Fri Aug 01 00:37:21 14
The datecode is: 2014200
The pro machine type is: x86e_win64
The process ID is: 5836
The traceback type is : CRASH
Exception EXCEPTION_ACCESS_VIOLATION has occurred in the thread 4580.
Main Thread 4580
Somes sugest to add (enable_opengl_fbo no) to the config.sub. It does not work.
I used to get this error with complicated result window for multipal components. Now, I get it with only 1 result window for 1 part..
Thank you and best regards
Dung,
if you can reproduce the problem on simple model, then contact PTC Support.
Martin Hanak
This happens to me all the time. I am pretty sure there is a memory error somewhere. The problem is it doesn't happen all the time although it is somewhat frequent. The fact that it doesn't happen all the time makes it harder to open a ticket for.
Hi All
This problem played with me for a long time since Pro/e Wild fire 2. It is getting worst after I added a second monitor. It pissed me off
I figured out the way to fix this last night. Here how it works for me. It might not work for all.
Right click on the screen
Select personalization
change it to windows 7 basic
Best regards
