I have a new network install of Creo 4.0 m070 and I am getting 2 messages when I start up.
1) EFX failed to load
2) Exit Logger did not initialize correctly.
I have had Creo 4 m060 running on a different network since last fall and have not seen these errors on that system.
Any suggestions as to what I need to change on the setup to fix these issues.
I am not connected to Windchill, yet. Want to get a native Creo 4 running before adding the Windchill stuff.
I found some EFX documents, but they only pointed to it being a Microsoft DLL issue. I have contacted the IT department to load the newer DLL's. We can live with this warning until IT fixes our systems.
The second issue is fixed with a startup change between Creo2 and Creo4. Creo 2 only required Creo_Agent_Exe_Path. Creo 4 requires that plus Creo_Agent_LDP_List.
my suggestion ... report problems to PTC Support.
Note: I found 2 documents related to EFX problem.
