Error occurs when I use external coefficients field
ptc-5247809
I have some problems with Pro Engineer Wildfire 4.0 University Edition.
When I use external coefficients field with Pro mechanica to import pressure field from CFD simulation, the following error message occurs : "The selected FNF file does not have matching load/constraint data".However, I create FNF file as shown in the help.
What does that mean ?
Thank,
Maxime
0 REPLIES 0
