I changed my network card and now I can't move my licence
Hi Martin,
I managed to fix it myself. I found that I had 2 problems:
- The license file did have the SERVER and DAEMON lines, but were not customized for the PC I was working on.
- The FlexNet server was not running properly and giving error messages when I made queries about the license status.
After I fiddle with both issues, the license did end up working.
As for question 2, I'm running CREO 3.0 Parametric and it seems to work fine.
Licenses are tied to the MAC address. You will need to log on to PTC's license support website and request a license move from the old hardware to the new hardware. It's pretty quick and completely automated.
You need to contact PTC to have your license file updated. This is a process but it shouldn't require an active maintenance.
...yes, what Tom said ![]()
Already done, but when I want to setup the licence, (with the TXT file I received from them, the status is Starting.... And nothing
if you use lmadmin license manager installed in C:\Program Files\PTC\FLEXnet Admin License Server directory then:
Martin Hanak
Ok!
There is not folder on (C:\Program Files\PTC\FLEXnet Admin License Serve) But into my Services.msc I have FLEXnet Licencing Service (started) (I checked on C:\Program Files (x86) and nothing)
Where can I find this Program ? ''Flexnet''
Hi Martin Hanak I change the (licence.dat) following your steps (mine, is licence.txt it'S normal ? ) and Finally I Installed the software, but I have this message when I open it
If I say Ok the software is closed
Pierre,
we have to start from the very beginning ...
Question no.1: Does your license file (received from PTC) contain SERVER and DAEMON lines ?
Example related to my notebook:
SERVER hpmh PTC_HOSTID=1C-C1-DE-BA-30-44 7788
DAEMON ptc_d D:\PTC\flexnet\x86e_win64\obj\ptc_d.exe D:\PTC\flexnet\licensing\ptc.opt port=7789
Question no.2: Your picture contains information about PROE_FoundationAdv and Mechanism_Design (Version=32.0). This means that the license enables you to run PTC software up to Creo Parametric 1.0. What software version do you use ?
Martin Hanak
Hi Martin,
Congratulations ! ![]()
You may mark appropriate replay in post as correct answer.
