License request failed for feature
SP_9714425
2-Explorer
The message:
Hi, I've been reeding some similar topics but none of them helped me solve my problem.
What sould I do ?
There is my ipconfig/all:
There is my licensing file:
######### Creo Direct Modeling Education (Student) #########
#Feature Line Type = INCREMENT
#Feature Name = CREODMA_Student3
#Feature Version = 38.0
#Version = Creo 7.0
#Number of Copies = uncounted locked license
#Supercede = Y
#Issue Date = 27-NOV-2020
#Expiration Date = 28-NOV-2021
#Node Locked Option = Pro/ASSEMBLY
#Node Locked Option = Pro/FEATURE
#Node Locked Option = Pro/INTERFACE
#Node Locked Option = WLO
#Node Locked Option = Pro/SURFACE
#Node Locked Option = Pro/INTERFACE for STEP
#Node Locked Option = Student
#Node Locked Option = Language Option - CHINESE Educational
#Node Locked Option = Creo Flexible Modeling
#Node Locked Option = Creo Unite
INCREMENT CREODMA_Student3 ptc_d 38.0 28-nov-2021 uncounted \
80C0C060227C05A4E1D2 VENDOR_STRING="VSVER=2.0 \
LO=(6,7,17,19,32,69,110,155,326,336)" \
HOSTID=PTC_HOSTID=B8-81-98-A4-34-2C SUPERSEDE \
ISSUER=PTC-WEB-CREOSTUDENT7 ISSUED=27-NOV-2020 \
NOTICE="toon.borghijs@student.kuleuven.be, " \
SIGN2="094B B179 D283 0E2A 78D1 F685 60D5 FF7E 6257 \
F01B 99A7 DEEF 1D2A F641 E177 19FA 0697 8906 AC3D \
0AC2 BD8D 6B6D 1568 6421 B792 A27B 50F8 2698 7BAB \
139D"
######### Creo Layout Student #########
#Feature Name = CREOLAY_Student3
#Version = Creo 7.0
#Supercede = Y
#Node Locked Option = Creo Layout Module
INCREMENT CREOLAY_Student3 ptc_d 38.0 28-nov-2021 uncounted \
50303040D18DD91ECE58 VENDOR_STRING="VSVER=2.0 \
LO=(6,7,17,19,32,69,110,291,326,336)" \
SIGN2="0A33 0623 5FA0 1040 C8CE 54D3 570D 0728 C681 \
A9B3 1221 279D D7C6 B252 CB93 1739 2F64 1A31 B02C \
0404 DCBD F189 733A 796D 97C8 BC6A 5EA9 BABA 6EC9 \
999C"
######### Creo Illustrate Standard #########
#Feature Name = CREOILLUS_STANDARD
#Feature Version = 7.0
#Version = Creo 7.0
#Supercede = Y
INCREMENT CREOILLUS_STANDARD ptc_d 7.0 28-nov-2021 \
uncounted D00060F02F2AE1FC4BB2 \
VENDOR_STRING="VSVER=2.0 LO=(19)" \
SIGN2="1531 5BA7 EFAE 044A 81E7 66E8 3182 F801 6B5D \
738E FEA1 AA14 B73A 851E 79DA 17C8 992F 7869 ECB6 \
BC72 C7D1 61F8 6749 181B 7AEA 9727 0017 BAAD 2BC6 \
5FA4"
######### Creo Student Edition Standard #########
#Feature Name = CREOPMA_Student6
#Version = Creo 7.0
#Supercede = Y
#Node Locked Option = NOTEBOOK
#Node Locked Option = ASSEMBLY
#Node Locked Option = FEATURE
#Node Locked Option = DETAIL
#Node Locked Option = INTERFACE
#Node Locked Option = SURFACE
#Node Locked Option = PLOT
#Node Locked Option = CABLING
#Node Locked Option = REPORT
#Node Locked Option = PIPING
#Node Locked Option = INTERFACE for STEP
#Node Locked Option = PHOTORENDER
#Node Locked Option = SHEETMETAL-DESIGN
#Node Locked Option = Mechanism Design License
#Node Locked Option = Behavioral Modeling License
#Node Locked Option = Import Data Doctor
#Node Locked Option = Design Animation
#Node Locked Option = Interactive Surface Design Extension Module
#Node Locked Option = Mechanism_Dynamics
#Node Locked Option = Advanced Rendering Extension 2
#Node Locked Option = Creo Freestyle Design
#Node Locked Option = Mold Analysis Lite
#Node Locked Option = GDT Advisor
#Node Locked Option = Creo Render Studio
#Node Locked Option = Additive Manufacturing
INCREMENT CREOPMA_Student6 ptc_d 38.0 28-nov-2021 uncounted \
F070E0B0D4E406B29A1C VENDOR_STRING="VSVER=2.0 \
LO=(0,6,7,10,17,19,32,34,48,51,61,69,73,110,115,127,128,135,137,155,188,191,283,325,326,336,347,354,357,361)" \
SIGN2="1FD9 BA48 8947 2EA6 4C31 8E46 C956 7F89 DEF8 \
9C8C 3A1E 7E6C A066 E004 ADCE 1C6B A1D4 49BE 8FD6 \
99C7 BBEF 8479 EBEF 61A9 F3E6 60EE 77D8 809C 9240 \
6680"
Thanks, and please @MartinHanak help me 😊
3 REPLIES 3
BenLoosli
(To:SP_9714425)
Run the utility PTCstatus and see what IP address that gives. This is the address that must be used in your license file. Your #1 wireless address may not be the one that PTCstatus returns.
@SP_9714425 wrote:
The message:
What sould I do ?
#Version = Creo 7.0
#Supercede = Y
139D"
#Version = Creo 7.0
#Supercede = Y
999C"
#Version = Creo 7.0
#Supercede = Y
5FA4"
#Version = Creo 7.0
#Supercede = Y
6680"
edit parametric.psf file in Notepad.
Replace CREOPMA_Student7 with CREOPMA_Student6
Martin Hanák
 Not sure if this would help, but I have Mac and use parallels and had this issue. All I did was run the program directly from the folder it's in, not from the icon on the desktop screen.
To make it work all I did was find Creo in the windows folder (not command window). For me it was in PC:Program Files:PTC:Creo
and then you should see a folder called "Parametric"-click into it. Then inside that click into the "bin" folder. Then just double click "Parametric" that is APP type.
Hope that helps.
