When I add a new masterdata to modelmanager most of the attributes are blank. I'd like to create a saved search in model manager for parts where I'm the owner but a specific attribute is blank ?
Any way to do this ?
Mike
(I'd love to have searched the forum for any similar requests but I'm dammed if I could spot a search facility)
Found it , enter NULL in the attribute search box.
Mike
Would you mind post a screen shot of your solution?
Thanks!
MIke
Possibly this won't work for all fields so ymmv.
Sorry, I don't have the answer to your Model Manager search question, but the forum search is in the upper right in my browser.
Mike
Thanks, guess I was epecting something that looked like it was more associated with the forum rather than a general site search.
Mike
Mike M., the "search" you highlighted (in the upper right Corner) is the so called "search for everything" (=searches within the UNIQE_ID_STRING only)
The UNIQUE_ID_STRING of an element (DOC, MASTERDATA, just everything you have in the DB) can never be empty, so entering NULL in
the search field does not make sense.
Entering "NULL" only makes sense when you open the "Search" Tab to search for Models, Drawings etc.
This is what Mike B. correctly described.
Hope this helps.
