Sublevel Modelcheck error not showing in top level Modelcheck regeneration for all also
Harsha_D
7-Bedrock
Hello All,
I am having an sample assembly (with 2 sub part in it) on which I am running Modelcheck on all level on main assembly. Showing me  0 error.
When I open subpart & ran Modelcheck showing an error layer.
My question is, why sublevel error is not picked by Top level modelcheck run even after I ran for all sub level. PFA screenshots for clarification.
I got the solution, To check the sublevel errors in Top level assembly we need to change the values for Modelcheck settings in file config.init.mc from Modelcheck settings:
1. CHECK_ALL_MODELS = Y
2. SKIP_MODELS: N
To get clear, find the attached snaps.
StephenW
(To:Harsha_D)
I think you have to click on "assembly failed" to get sub level part information.
BenLoosli
(To:Harsha_D)
Each file processed by ModelCheck generates its own set of files. You would need to open the sub-file MC report to see its failures.
2. SKIP_MODELS: N
