This widget could not be displayed.
config option to create drawing with new part.
snguyen
Good morning,
Is there an config option that in an assembly. If I use Edit>Replace>By Copy
that the new component that is being created will have the drawing too. One
of the designers says that he was able to do it before until I gave him a
new config.pro file.
Thanks.
Son Nguyen
785-667-7763
108 W. 2nd Street
Assaria, Kansas 67416
snguyen
(To:snguyen)
I tried with this config option but the new copied part still has no
drawing.
rename_drawings_with_object both (Drawing and part name have to match)
Any other option before I tell him that it can not be done.
davehaigh
(To:snguyen)
That only works if the drawing and the model are the same name. If the original names are different, the it will not work.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
msproe
2-Explorer
(To:snguyen)
The drawing has to be in the same directory or in session or have a search
path pointing to it also. If Pro can't find the drawing it will not copy
it along with the part.
Kim
"Haigh, David A." <->
02/23/2010 01:30 PM
Please respond to
To
Son Nguyen <->, "-"
cc
Subject
[proecad] - RE: config option to create drawing with new part.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
snguyen
(To:snguyen)
If I do a File>Save a Copy then it works like it should. The new part that
is a copy of the original has the drawing rename to the new name and linked
to the new part.
But when I am using Edit>Replace>Copy As a component in an assembly it will
not work. The original part is rename but the drawing is not copied.
The weird thing is I can get it to work in an Intralink workspace.
This is really bugging me.
Any help will be appreciated.
We are using Product Point... and I have seen this as well when connected to
it. PTC is aware of this and will supposedly fix it in an upcoming release.
The solution ( work around ) is to have ONLY the Part-or-Assembly in
Session... You cannot have the DRW open or in session when you perform the
saveas.
-todd
