hyd hose w/ different routings
jrichardson
we have a hyd hose assembly thathas a fixed link with a single part number. it is used in different locations with different route paths.
i can't figure out how to route the same asembly p/n along different paths. has anyone out there done this type of configuration before?
i'm sure someone has. any help would be great.
thanks for your time.
John Richardson
Sr. Designer
Niitek
Dulles, VA
Hi John,
I have dealt with this many times.
The "PTC suggested" solution is a workaround.
Basically, after the first routing, you need to create an "_1" routing
and so on.
I have an alternative that I am toying with.
What if you routed to a set of points that were table driven?
Then you had multiple instances in your family table.
X, Y, and Z dimensions for each point would be dimensions in your table.
It would require some effort of course, all dependent on how badly
you wanted your routings to be legitimately related. You could name
family table instances after the application. Let me know what you end
up doing.
Thanks much,
Frederick Burke
Avionics Installations Engineer
Fire Scout VTUAV - Unmanned Systems
Northrop Grumman Corporation
858-618-7163
858-618-7186 (FAX)
