Why is NVidia FX1800 in a DELL T3500 not Certified or Suppor
  • February 22, 2010
  • 3067 views
Looking at the system requirements for Wildfire 5.0, I see that the NVIDIA Quadro FX580 is Certified and the NVIDIA Quadro FX3800 is Supported on a Dell Precision T3500. See here.. http://www.ptc.com/WCMS/files/96289/en/dell_wf5.pdf Why is the Nvidia Quadro FX1800 not Certified or Supported on a T3500? The video card is Certified and Supported on other Precision builds. I assume that there wouldn't be a problem but i don't want to jump to conclusions. Does anyone have a similar set up? Have you had any problems?
In order to get certified each configuration must be tested, therefore PTC must have every flavor from Dell ($$). I'm sure your Dell setup will work fine. You get into problems when you don't use standard computer hardware. Using a gaming card instead of a workstation card would be an example.
Hi Amilcar Martinez I have nVidia Quadro FX 1700 Card in T7400 similar than yours and don't have any problem. It's works perfectly.
