version number on Pro/E files
ptc-106508
2-Explorer
Is there a way to turn off the dot number on the end of all of the Pro/E files?
To: top_case.prt
I was wondering if there is a hidden config.pro option.
Mark Nerby
Fluke Corporation
mark.nerby@fluke.com
6 REPLIES 6
davehaigh
(To:ptc-106508)
No there isn't.
That's how ProE keeps track of versions. It even happens in your Windchill cache, but it's just hidden from you. If you use the workspace cache recovery tool you will see that all the versions are there.
David Haigh
BenLoosli
(To:ptc-106508)
The best you can do is a purge and then rename the files that are left.
Thank you,
Ben H. Loosli
USEC, INC.
cfly
(To:ptc-106508)
You might be able to tell Windows Explorer to hide them in the folder
display, but then you'd have a whole bunch of files that appear to be the
same. Dangerous business.
efefefefefefef
Applied Research Labs
University of Texas at Austin
Carol Fly
Mechanical Designer
(512) 835-3397
Fax (512) 835-3259
efefefefefefef
_____
I need to ask. Why would you want to loose the extension?
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
8940 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 266-2359
If you were to do that, then your PC might think it's looking at UG-NX files. They end in .prt with no version number.
Bob
Dukane Corp.
BenLoosli
(To:ptc-106508)
Only if NX was installed after Pro/E. PTC takes the .prt extension, too, as the default open for file type.
Thank you,
Ben H. Loosli
USEC, INC.
