Best Way to get Alerts/Events on the Tags Quality
pshashipreetham
I want to get Alerts or configure events based on the Tag Quality(Kepware Tag Quality). What will be the best way to do it?
@c_lowy can you help me out on this ?
Shashi
Shashi Preetham,
Email: psp316r@outlook.com,
Mobile: +91 8099838001.
@pshashipreetham Usually if the property has not been updated even once, then it will show this default time value for last updated. Please check for a property if it has been updated even once. Also are these properties marked as 'Logged' and 'persistent'?
6 REPLIES 6
Hi @abjain
I have checked the blog before I posted mine, how can we check if the kepware is connected or not !!
Shashi
Shashi Preetham,
@pshashipreetham On the industrial connection thing which is connected to Kepware, you can check the isConnected property. If its true than Kepware is connected. You can write a subscription to the property.
Hi @abjain
I did it when it is disconnected the Quality of Properties of Industrial things are UNKNOWN, so when I try to get the last timestamp of the data pushed to that particular property using GetPropertyTime it gives me the "Thu Jan 01, 1970, 05:30:00"  as output.
is it possible to get the proper time of the last pushed data when the Property quality is "UNKNOWN"
Shashi Preetham,
abjain
(To:abjain)
@pshashipreetham If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
