Cannot access Thingworx Server web pages
XiangwenZhu
3-Newcomer
I installed AnalyticsBuilder trial edition on Windows 10. Everything works fine at the beginning. I can access http://10.0.75.1:8080/Thingworx and finish tasks following the tutorial. After several hours, I found I cannot access the web pages. IE shows:
Can’t reach this page
Then I tried a different IP 10.0.75.2 and it works. After a weekend, I cannot access Thingworx web page by any IP. I have tried to restart the services. It doesn't work.
I have cleaned everything and reinstalled ATE again. The installation log shows everything is fine, but the problem is the same. The web site only works for few hours.
cmorfin
(To:XiangwenZhu)
Hi
Okay, so the twxfoundation, edgems and nginx containers are in Exited state, this is why you cannot access ThingWorx.
You will need to start them manually: docker start twxfoundation for example.
Make sure you have allocated at least 6 Gb of RAM to the docker process, and ensure your local machine has at least 16Gb of RAM.
Kind regards
Christophe
4 REPLIES 4
cmorfin
(To:XiangwenZhu)
Hi
Could you post the output of the below 2 commands
docker ps -a
ipconfig /all
Christophe
cmorfin
(To:XiangwenZhu)
Hi
Kind regards
Christophe
The problem is solved. Perfect.
