Checkbox changed event to fire navigate service
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
I have a service set up in a mashup that returns a true or false value. I have that result tied to a checkbox widget. I have the checkbox changed event tied to a navigation widget navigate service. When the original service in the mashup runs, it changes the checkbox value from a default of false to true, however the navigation widget does not initiate its navigate service. If I manually click the checkbox, the navigation widgets navigate service will fire.
Any help would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Michael, what you can do is to use the Service Invoke Completed to fire the Navigation Widget as well.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Pai,
Thank you for the quick response. Is there a way I can have the expression field for the validator check the value of a returned selected row from a service and if it equals a certain value, return true? Not sure exactly how I could reference service results within the expression field of the validator.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Pai,
Thanks for the direction.
I was able to figure it out. Added the parameter for the true/false value from the service to be brought into the validator. Then simply set the validator expression to "Output = Navigate_Boolean" and have the true event set to the navigation widgets navigate event.
![](/skins/images/695EE5AD3E567050FEDD72575855ED93/ptc_skin/images/icon_anonymous_message.png)
