Connect Agent .NET by WSS to Thingworx
AlessandroN
11-Garnet
Hi all,
I'm trying to connect my .NET agent to Thingworx using a secure websocket connection (WSS), I've already configured my tomcat, and from Chrome it works successfully on HTTPS.
1 - Every time i try to connect, the client gives me back this error
(ATTACHED_1)
2 - the client has been configured this way, using a config file for edit connection's details.
(ATTACHED_2)
3 - I can't understand why i have to specify the location of the Server Certificate on the Client side!
     Doesn't it should be retrieved by the client on the initial handshake?
Thanks in advance!!
7 REPLIES 7
ckaminski
(To:AlessandroN)
Hello, Allessandron:
Can you please post the error you are seeing?  It does not show up in the post.
-Chris Kaminski
Hi ckaminski, I'm sorry for that :D
I've just edited.
ckaminski
(To:AlessandroN)
Ideally the server would provide it's public key and the intermediate CA key as well to build a route of trust to a known root.   If you have no known roots in your environment you would need to provide that to the end device.
Are you using a self-signed certificate?  Is so, the following properties are set to true, I assume:
  • ClientConfigurator.AllowSelfSignedCertificates = true
  • ClientConfigurator.DisableCertValidation = true
Hi, yes my configuration is:
// TLS
            CertFileInfo serverCertFileInfo = new CertFileInfo();
            serverCertFileInfo.FilePath = ConfigurationManager.AppSettings["ServerCertificateFilePath"].ToString();
            serverCertFileInfo.CertType = 1; // '0' for axTLS
            config.ServerCertFileInfo = serverCertFileInfo;
            CertFileInfo clientCertFileInfo = new CertFileInfo();
            clientCertFileInfo.FilePath = ConfigurationManager.AppSettings["ClientCertificateFilePath"].ToString();
            clientCertFileInfo.CertType = 1; // '0' for axTLS
            config.ClientCertFileInfo = clientCertFileInfo;
            KeyFileInfo keyFileInfo = new KeyFileInfo();
            keyFileInfo.FilePath = ConfigurationManager.AppSettings["ClientKeyFilePath"].ToString();
            keyFileInfo.Passphrase = ConfigurationManager.AppSettings["ClientKeyFilePassphrase"].ToString();
            keyFileInfo.KeyType = 0;
            config.ClientKeyFileInfo = keyFileInfo;
            config.AllowSelfSignedCertificates = Boolean.Parse(ConfigurationManager.AppSettings["AllowSelfSignedCertificates"].ToString());
            config.DisableCertValidation = Boolean.Parse(ConfigurationManager.AppSettings["DisableCertValidation"].ToString());
For the certificates, I'm using self-signed and I created them for the CA, .NET Application and TW Tomcat.
1- On the tomcat I've already set up the server.conf, indeed I'm able to use HTTPS by Chrome)
2- Chrome shows it as trusted, since I added the CA cert to my Windows (Client) trusted roots.
3- Actually i don't wanna validate Client cert on the server, just validate the Server.
3- I'm not able to connect with Thingworx over WSS since on the client it gives me back this error: "com.thingworx.communications.client.TwApiWrapper Error: 0 : [Error] twWs_Connect: Error trying to connect"
Hi Alessandro,
What flavor of the .NET SDK are you using ? FIPS or AxTLS ?
slangley
23-Emerald II
(To:AlessandroN)
Hi @AlessandroN.
If you have found a solution to your problem, please post it here or mark one of the previous responses as the Accepted Solution.  If you are still having issues, please let us know.
--Sharon
slangley
23-Emerald II
(To:AlessandroN)
Hi @AlessandroN.
From reviewing the information you provided, there could be a number of things going on.  With your approval, I will be happy to open a case for this so that it can be worked over a WebEx.
Please let me know if you would like to move forward with that approach.
--Sharon
