Hi all,
Like the subject, I would like to create a top-right delete image button for value display widget (like the image below)
Is there any way to perform it?
Any help is appreciated.
Thanks!
Which part is not clear?
1. Overlap the Button widget with the ValueDisplay widget, put it in top-right corner.
2. Change the Button Style with a X image (I don't have that at hand, use another one)
In mashup it looks like
3. Figure out the "Close/ delete image" logic in a service and trigger it by this Button. (Don't know how you want to delete image in ValueDisplay, so you need to do the customization yourself)
Yes you can, the Button widget can overlap with the valueDisplay widget, and occupy the top-right part of the image.
And then, you need to change the Button Style with a X image, and figure out the "Close/ delete image" logic in a service and trigger it by this Button.
Thank @zyuan1 , but could you explain more details for me? (An example maybe)
