CreateDashboard fails in Thingworx 7.2 (PostgreSQL)
SOLVED
Regular Member
We have integrated PostgreSQL (version 9.4/9.5)  with Thingworx7.2 . We are getting below error when calling CreateDashboard
Resources["DashboardFunctions"].CreateDashboard(params);
NOTE: Please note that this works fine with Thingworx 7.2 WITHOUT PostgreSQL
Error =>
: Wrapped java.lang.Exception: Import Failed: Not authorized for Create Cause: Import Failed: Not authorized for
Tags (1)
1 ACCEPTED SOLUTION
Re: CreateDashboard fails in Thingworx 7.2 (PostgreSQL)
there were permissions defined in data table.
The data table was not imported correctly.
After importing the issue is resolved.
14 REPLIES 14
Are you logged in as  Administrator?
Highlighted
Hi Thomas, could you please clarify what you meant with integrated PostgreSQL version 9.4 & 9.5? Which version is used as the persistence provider for ThingWorx 7.2?
What sort of user did you use to create the dashboard?
We are using  PostgresSQL 9.5 as thingsworx storage.
We are using  ThingworxPersistenceProvider (Persistence provider package :).
CreateDashboard is being executed by user .
Please note that it works fine with Thingworx 7.2 with Neo4j as ThingworxPersistenceProvider .
PostgreSQL 9.5 is currently not supported. Please install the latest minor version of 9.4 (9.4.12)
We have different instance, which is configured to 9.4 and getting same below error
Wrapped java.lang.Exception: Import Failed: Not authorized for Create Cause: Import Failed: Not authorized for Create]
Is the User an Administrator? Because otherwise this is just a permission issue.
User has permission to execute "CreateDashboard", user is not Administrator
Please check if it works with Administrator user, then we will look into permissions layer by layer
It works fine with Administrator user.
Below is the stack trace of normal user.
Error=
        at java.lang.Thread.run(Thread.java:745)
  1. com.thingworx.common.exceptions.InvalidRequestException: Not authorized for Create
        at com.thingworx.system.managers.BaseManager.generateSecurityException(BaseManager.java:499)
        at com.thingworx.system.managers.BaseManager.checkDesignTimePermission(BaseManager.java:458)
        at com.thingworx.system.managers.BaseManager.checkCreatePermission(BaseManager.java:503)
        at com.thingworx.system.managers.BaseManager.createEntity(BaseManager.java:224)
        at com.thingworx.contentmanagement.ImportProcessor.processImport(ImportProcessor.java:471)
        at com.thingworx.resources.dashboards.DashboardFunctions.CreateDashboard(DashboardFunctions.java:96)
       at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:483)
        at com.thingworx.common.processors.ReflectionProcessor.processService(ReflectionProcessor.java:261)
        at com.thingworx.handlers.ReflectionServiceHandler.processService(ReflectionServiceHandler.java:48)
        at com.thingworx.entities.helpers.InternalServiceHelper.processServiceRequestDirect(InternalServiceHelper.java:115)
        at com.thingworx.entities.helpers.InternalServiceHelper.processServiceRequest(InternalServiceHelper.java:71)
        at com.thingworx.entities.ServiceProviderEntity.processServiceRequest(ServiceProviderEntity.java:53)
        at com.thingworx.dsl.engine.adapters.VirtualFunction.call(VirtualFunction.java:145)
        at org.mozilla.javascript.optimizer.OptRuntime.call1(OptRuntime.java:32)
        at org.mozilla.javascript.gen.PopulateDashboardByDefault_543._c_script_0(PopulateDashboardByDefault:7)
        at org.mozilla.javascript.gen.PopulateDashboardByDefault_543.call(PopulateDashboardByDefault)
        at org.mozilla.javascript.gen.PopulateDashboardByDefault_543.exec(PopulateDashboardByDefault)
        at com.thingworx.dsl.engine.DSLProcessor.executeService(DSLProcessor.java:167)
        at com.thingworx.dsl.DSLServiceHandler.processService(DSLServiceHandler.java:37)
        at com.thingworx.things.Thing.processServiceRequestDirect(Thing.java:6657)
        at com.thingworx.things.Thing.processServiceRequest(Thing.java:6575)
        at org.mozilla.javascript.optimizer.OptRuntime.callProp0(OptRuntime.java:85)
        at org.mozilla.javascript.gen.SetCurrentMainDashboard_498._c_script_0(SetCurrentMainDashboard:2)
        at org.mozilla.javascript.gen.SetCurrentMainDashboard_498.call(SetCurrentMainDashboard)
        at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:394)
        at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3090)
        at org.mozilla.javascript.gen.SetCurrentMainDashboard_498.exec(SetCurrentMainDashboard)
        at com.thingworx.things.Thing.processAPIServiceRequest(Thing.java:6595)
        at com.thingworx.webservices.BaseService.handleInvoke(BaseService.java:2931)
        at com.thingworx.webservices.BaseService.service(BaseService.java:327)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
        at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
        at com.thingworx.security.contenttype.ContentTypeFilter.doFilter(ContentTypeFilter.java:111)
        at com.thingworx.security.filter.ValidationFilter.doFilter(ValidationFilter.java:22)
        at com.thingworx.security.authentication.AuthenticationFilter.propagateRequest(AuthenticationFilter.java:370)
        at com.thingworx.security.authentication.AuthenticationFilter.doFilter(AuthenticationFilter.java:150)
        at com.thingworx.security.filter.ClickjackFilter.doFilter(ClickjackFilter.java:32)
        at com.thingworx.security.filter.ProhibitIfNotLeaderFilter.doFilter(ProhibitIfNotLeaderFilter.java:119)
        at com.thingworx.security.filter.HttpResponseHeadersFilter.doFilter(HttpResponseHeadersFilter.java:52)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:212)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
        at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:522)
        at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1095)
        at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:672)
        at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1502)
        at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1458)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
