CreateDashboard fails in Thingworx 7.2 (PostgreSQL)
ThomasMathew
We have integrated PostgreSQL (version 9.4/9.5)  with Thingworx7.2 . We are getting below error when calling CreateDashboard
Resources["DashboardFunctions"].CreateDashboard(params);
NOTE: Please note that this works fine with Thingworx 7.2 WITHOUT PostgreSQL
Error =>
: Wrapped java.lang.Exception: Import Failed: Not authorized for Create Cause: Import Failed: Not authorized for
there were permissions defined in data table.
The data table was not imported correctly.
After importing the issue is resolved.
14 REPLIES 14
Are you logged in as  Administrator?
Hi Thomas, could you please clarify what you meant with integrated PostgreSQL version 9.4 & 9.5? Which version is used as the persistence provider for ThingWorx 7.2?
What sort of user did you use to create the dashboard?
We are using  PostgresSQL 9.5 as thingsworx storage.
We are using  ThingworxPersistenceProvider (Persistence provider package :).
CreateDashboard is being executed by user .
Please note that it works fine with Thingworx 7.2 with Neo4j as ThingworxPersistenceProvider .
PostgreSQL 9.5 is currently not supported. Please install the latest minor version of 9.4 (9.4.12)
We have different instance, which is configured to 9.4 and getting same below error
Wrapped java.lang.Exception: Import Failed: Not authorized for Create Cause: Import Failed: Not authorized for Create]
Is the User an Administrator? Because otherwise this is just a permission issue.
User has permission to execute "CreateDashboard", user is not Administrator
Please check if it works with Administrator user, then we will look into permissions layer by layer
It works fine with Administrator user.
Below is the stack trace of normal user.
Error=
        at java.lang.Thread.run(Thread.java:745)
  1. com.thingworx.common.exceptions.InvalidRequestException: Not authorized for Create
        at com.thingworx.system.managers.BaseManager.generateSecurityException(BaseManager.java:499)
        at com.thingworx.system.managers.BaseManager.checkDesignTimePermission(BaseManager.java:458)
        at com.thingworx.system.managers.BaseManager.checkCreatePermission(BaseManager.java:503)
        at com.thingworx.system.managers.BaseManager.createEntity(BaseManager.java:224)
        at com.thingworx.contentmanagement.ImportProcessor.processImport(ImportProcessor.java:471)
        at com.thingworx.resources.dashboards.DashboardFunctions.CreateDashboard(DashboardFunctions.java:96)
       at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:483)
        at com.thingworx.common.processors.ReflectionProcessor.processService(ReflectionProcessor.java:261)
        at com.thingworx.handlers.ReflectionServiceHandler.processService(ReflectionServiceHandler.java:48)
        at com.thingworx.entities.helpers.InternalServiceHelper.processServiceRequestDirect(InternalServiceHelper.java:115)
        at com.thingworx.entities.helpers.InternalServiceHelper.processServiceRequest(InternalServiceHelper.java:71)
        at com.thingworx.entities.ServiceProviderEntity.processServiceRequest(ServiceProviderEntity.java:53)
        at com.thingworx.dsl.engine.adapters.VirtualFunction.call(VirtualFunction.java:145)
        at org.mozilla.javascript.optimizer.OptRuntime.call1(OptRuntime.java:32)
        at org.mozilla.javascript.gen.PopulateDashboardByDefault_543._c_script_0(PopulateDashboardByDefault:7)
        at org.mozilla.javascript.gen.PopulateDashboardByDefault_543.call(PopulateDashboardByDefault)
        at org.mozilla.javascript.gen.PopulateDashboardByDefault_543.exec(PopulateDashboardByDefault)
        at com.thingworx.dsl.engine.DSLProcessor.executeService(DSLProcessor.java:167)
        at com.thingworx.dsl.DSLServiceHandler.processService(DSLServiceHandler.java:37)
        at com.thingworx.things.Thing.processServiceRequestDirect(Thing.java:6657)
        at com.thingworx.things.Thing.processServiceRequest(Thing.java:6575)
        at org.mozilla.javascript.optimizer.OptRuntime.callProp0(OptRuntime.java:85)
        at org.mozilla.javascript.gen.SetCurrentMainDashboard_498._c_script_0(SetCurrentMainDashboard:2)
        at org.mozilla.javascript.gen.SetCurrentMainDashboard_498.call(SetCurrentMainDashboard)
        at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:394)
        at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3090)
        at org.mozilla.javascript.gen.SetCurrentMainDashboard_498.exec(SetCurrentMainDashboard)
        at com.thingworx.things.Thing.processAPIServiceRequest(Thing.java:6595)
        at com.thingworx.webservices.BaseService.handleInvoke(BaseService.java:2931)
        at com.thingworx.webservices.BaseService.service(BaseService.java:327)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
        at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
        at com.thingworx.security.contenttype.ContentTypeFilter.doFilter(ContentTypeFilter.java:111)
        at com.thingworx.security.filter.ValidationFilter.doFilter(ValidationFilter.java:22)
        at com.thingworx.security.authentication.AuthenticationFilter.propagateRequest(AuthenticationFilter.java:370)
        at com.thingworx.security.authentication.AuthenticationFilter.doFilter(AuthenticationFilter.java:150)
        at com.thingworx.security.filter.ClickjackFilter.doFilter(ClickjackFilter.java:32)
        at com.thingworx.security.filter.ProhibitIfNotLeaderFilter.doFilter(ProhibitIfNotLeaderFilter.java:119)
        at com.thingworx.security.filter.HttpResponseHeadersFilter.doFilter(HttpResponseHeadersFilter.java:52)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:212)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
        at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:522)
        at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1095)
        at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:672)
        at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1502)
        at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1458)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
Try opening dev tools of your browser (f12 in chrome) and seeing the errors there. At this point I would add permissions on the user to EntityServices resources and PlatformSubsystem, also collection permission on the dashboards. You may look into using the system user too: The use of System User
with Administrator , we can execute "CreateDashboard" service in composer ONLY but with Administrator also it fails
Thanks a lot for the help. We got the resolution.
Could you please mark the answers as correct or helpful if any of them were? This will help improve searching for our community in the future.
Thank you!
