CreateDashboard fails in Thingworx 7.2 (PostgreSQL)
  • July 25, 2017
  • 4 replies
  • 6162 views
We have integrated PostgreSQL (version 9.4/9.5)  with Thingworx7.2 . We are getting below error when calling CreateDashboard
Resources["DashboardFunctions"].CreateDashboard(params);
NOTE: Please note that this works fine with Thingworx 7.2 WITHOUT PostgreSQL
Error =>
: Wrapped java.lang.Exception: Import Failed: Not authorized for Create Cause: Import Failed: Not authorized for
Best answer by ThomasMathew
there were permissions defined in data table.
The data table was not imported correctly.
After importing the issue is resolved.
20-Turquoise
July 25, 2017
Are you logged in as  Administrator?
Hi Thomas, could you please clarify what you meant with integrated PostgreSQL version 9.4 & 9.5? Which version is used as the persistence provider for ThingWorx 7.2?
What sort of user did you use to create the dashboard?
We are using  PostgresSQL 9.5 as thingsworx storage.
We are using  ThingworxPersistenceProvider (Persistence provider package :).
CreateDashboard is being executed by user .
Please note that it works fine with Thingworx 7.2 with Neo4j as ThingworxPersistenceProvider .
It works fine with Administrator user.
Below is the stack trace of normal user.
Error=
        at java.lang.Thread.run(Thread.java:745)
  1. com.thingworx.common.exceptions.InvalidRequestException: Not authorized for Create
        at com.thingworx.system.managers.BaseManager.generateSecurityException(BaseManager.java:499)
        at com.thingworx.system.managers.BaseManager.checkDesignTimePermission(BaseManager.java:458)
        at com.thingworx.system.managers.BaseManager.checkCreatePermission(BaseManager.java:503)
        at com.thingworx.system.managers.BaseManager.createEntity(BaseManager.java:224)
        at com.thingworx.contentmanagement.ImportProcessor.processImport(ImportProcessor.java:471)
        at com.thingworx.resources.dashboards.DashboardFunctions.CreateDashboard(DashboardFunctions.java:96)
       at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:483)
        at com.thingworx.common.processors.ReflectionProcessor.processService(ReflectionProcessor.java:261)
        at com.thingworx.handlers.ReflectionServiceHandler.processService(ReflectionServiceHandler.java:48)
        at com.thingworx.entities.helpers.InternalServiceHelper.processServiceRequestDirect(InternalServiceHelper.java:115)
        at com.thingworx.entities.helpers.InternalServiceHelper.processServiceRequest(InternalServiceHelper.java:71)
        at com.thingworx.entities.ServiceProviderEntity.processServiceRequest(ServiceProviderEntity.java:53)
        at com.thingworx.dsl.engine.adapters.VirtualFunction.call(VirtualFunction.java:145)
        at org.mozilla.javascript.optimizer.OptRuntime.call1(OptRuntime.java:32)
        at org.mozilla.javascript.gen.PopulateDashboardByDefault_543._c_script_0(PopulateDashboardByDefault:7)
        at org.mozilla.javascript.gen.PopulateDashboardByDefault_543.call(PopulateDashboardByDefault)
        at org.mozilla.javascript.gen.PopulateDashboardByDefault_543.exec(PopulateDashboardByDefault)
        at com.thingworx.dsl.engine.DSLProcessor.executeService(DSLProcessor.java:167)
        at com.thingworx.dsl.DSLServiceHandler.processService(DSLServiceHandler.java:37)
        at com.thingworx.things.Thing.processServiceRequestDirect(Thing.java:6657)
        at com.thingworx.things.Thing.processServiceRequest(Thing.java:6575)
        at org.mozilla.javascript.optimizer.OptRuntime.callProp0(OptRuntime.java:85)
        at org.mozilla.javascript.gen.SetCurrentMainDashboard_498._c_script_0(SetCurrentMainDashboard:2)
        at org.mozilla.javascript.gen.SetCurrentMainDashboard_498.call(SetCurrentMainDashboard)
        at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:394)
        at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3090)
        at org.mozilla.javascript.gen.SetCurrentMainDashboard_498.exec(SetCurrentMainDashboard)
        at com.thingworx.things.Thing.processAPIServiceRequest(Thing.java:6595)
        at com.thingworx.webservices.BaseService.handleInvoke(BaseService.java:2931)
        at com.thingworx.webservices.BaseService.service(BaseService.java:327)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
        at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
        at com.thingworx.security.contenttype.ContentTypeFilter.doFilter(ContentTypeFilter.java:111)
        at com.thingworx.security.filter.ValidationFilter.doFilter(ValidationFilter.java:22)
        at com.thingworx.security.authentication.AuthenticationFilter.propagateRequest(AuthenticationFilter.java:370)
        at com.thingworx.security.authentication.AuthenticationFilter.doFilter(AuthenticationFilter.java:150)
        at com.thingworx.security.filter.ClickjackFilter.doFilter(ClickjackFilter.java:32)
        at com.thingworx.security.filter.ProhibitIfNotLeaderFilter.doFilter(ProhibitIfNotLeaderFilter.java:119)
        at com.thingworx.security.filter.HttpResponseHeadersFilter.doFilter(HttpResponseHeadersFilter.java:52)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:212)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
        at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:522)
        at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1095)
        at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:672)
        at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1502)
        at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1458)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
Thanks a lot for the help. We got the resolution.
20-Turquoise
July 27, 2017
Could you please mark the answers as correct or helpful if any of them were? This will help improve searching for our community in the future.
Thank you!
ThomasMathew5-Regular MemberAuthorAnswer
