Tree Widget and Remote File Structure
I'm using a tree widget in one of my mash up and use the TW.RSM.FileTransferHelper service GetDirectoryStructure( ) to populate the tree. The problem I have is that the tree widget only shows to the level as they are defined in the EMS config.json file.
However, if I pass the result data to a grid I can see that it actually returns data about sub folders.
Ideally I would like to show the sub folders on my tree, Does anyone know why the tree widget only shows to the first level?
Kieron
