Custom widget "Hello, World!" Issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
hi, i'm practice custom widget
TW.IDE.Widgets.helloWorld = function () {
this.widgetIconUrl = function() {
return "../Common/extensions/HelloWorld_ExtensionPackage/ui/helloWorld/helloWorld.ide.png";
this.widgetProperties = function () {
return {
"name": "Hello, World!",
"description": "An example widget.",
"category": ['Common'],
"properties": {
"Salutation": {
"baseType": "STRING",
"defaultValue": "Hello, World!",
"isBindingTarget": true
"TextSize":{
"baseType":"NUMBER",
"defaultValue":22,
"isBindingTarget":true
this.renderHtml = function () {
return "<div class=\"widget-content widget-helloWorld\">" +
"<span style=font-size: "+ this.getProperty("TextSize") +"px;>" + this.getProperty("Salutation") + "</span>" +
"</div>";
this.afterSetProperty = function (name, value) {
return true;
this.widgetEvents = function () {
return {
'Updated': {}
Hello, World We tried to construct a user widget that adjusts the font size by moving the slider using the example.(29 line)
However, the font size does not change.
The content inside is also unchanged.
How do I show the values that are bound in the widget?
- Tags:
- customizations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
seonho Cha: Please confirm if this issue is still open and need suggestions.
-Durgesh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi, Durgesh Patel
I am trying to create reactive text.
We're still trying it now.
thank
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hello, could you make it works in IDE (Composer) ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
origin hello word extension working
modified hello word extension working but, text size can't change
.salutation {
font-family: Impact, monospace;
font-size: text-size // <- it defined properties in ide.js
text-transform: uppercase;
I am weak in both span, style, and css.
After creating the responsive text, I want to create a thermometer widget.
I have a thermometer picture in the background and I plan to make it by adding Thingworx's vertical slider, but it's not possible at this time (because I do not know everything about span, style, css, value binding,
Is there any material that will help us to get direction in this situation?
thank
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
You can try with pure html to be sure that the css works.
Then in ThingWorx, on run time, can you see the css set in source code ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
ide and rue time have the same css.
- .salutation {
- font-family: Impact, monospace;
- font-size: text-size // <- it defined properties in ide.js
- text-transform: uppercase;
