ERROR com.thingworx.security.SecurityManagerBootstrapper - Failed to create SecurityManager
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Error message ::" ERROR com.thingworx.security.SecurityManagerBootstrapper - Failed to create SecurityManager, Failed to load SecretProvider
ERROR ErrorLog.com.thingworx.security.authentication.HAAuthenticationFilter - Failed to initialize HA Authentication
com.thingworx.exceptions.ConfigurationException: java.lang.RuntimeException: Failed to create SecurityManager, Failed to load SecretProvider "
I have tried to install Thingworx8.4 with Postgres.These are folder and created in D drive and give full control to system and users.
Kindly help me to resolve this issue.
Thank You
- Labels:
Install-Upgrade
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Can you please check this support article for this particular issue - https://www.ptc.com/en/support/article/CS305796
Let us know if performing the steps mentioned in the above article helps .
Mukul Narang
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Mukul Narang
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @SSMNKumar.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others on the community.
--Sharon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @SSMNKumar.
I have marked the Accepted Solution for this post. If you disagree, please let me know and I will remove it. If you are still having issues, please provide further details.
--Sharon
