Error message ::" ERROR com.thingworx.security.SecurityManagerBootstrapper - Failed to create SecurityManager, Failed to load SecretProvider
ERROR ErrorLog.com.thingworx.security.authentication.HAAuthenticationFilter - Failed to initialize HA Authentication
com.thingworx.exceptions.ConfigurationException: java.lang.RuntimeException: Failed to create SecurityManager, Failed to load SecretProvider "
I have tried to install Thingworx8.4 with Postgres.These are folder and created in D drive and give full control to system and users.
Kindly help me to resolve this issue.
Thank You
Can you please check this support article for this particular issue - https://www.ptc.com/en/support/article/CS305796
Let us know if performing the steps mentioned in the above article helps .
Mukul Narang
Mukul Narang
Hi @SSMNKumar.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others on the community.
--Sharon
Hi @SSMNKumar.
I have marked the Accepted Solution for this post. If you disagree, please let me know and I will remove it. If you are still having issues, please provide further details.
--Sharon
