Faile to enter Foundation for ThingworxAnalytics
MinNan
11-Garnet
hello
yesterday i was working on Thingworx Analytics,all was going well then.
but in the afternoon, i can't enter the Thingworx Foundation via http://10.0.75.1:8080/Thingworx/.
but it is strange that i can load the login interface like this
but when i sign in, i can't get any response, it just a banlk like this
i don't know what happens to my composor
Pleas help
Kind regards
Minnan
9 REPLIES 9
raluca_edu
(To:MinNan)
Check the ThingworxStorage/Application.log and also Tomcat logs, what errors do you see?
Raluca Edu
hi
i refer to the logs files, but i can't figure out where the problem is
int the attachment is the log file in the ThingworxStorage and Tomcat.could you help me?
Thx in advance
Minnan
raluca_edu
(To:MinNan)
Cannot see the logs, can you check?
sorry that i forget to attach the log file
raluca_edu
(To:MinNan)
Cannot open archives, there are some errors, please try to attach logs without archiving them.
i tried as you say.the file Application is from ThingworxStorage, the rest of which are from Tomcat
hello
it is strange that i can't upload the log feiles.
what else access can i send file to you?
Minnan
raluca_edu
(To:MinNan)
Use 'Reply' button, instead of 'Quick Reply', and try to attach again the files.
If you have PTC account, then you can open a case to PTC Support.
