18-Opal
April 21, 2023
Get the latest Timestamp from Infotable
  • April 21, 2023
  • 2 replies
  • 1694 views
 is there a way to get the latest timestamp entry from an InfoTable which has around 20 timestamps rows?
Best answer by pshashipreetham
hi @Velkumar ,
Thanks for it; I am not sure how I missed it.
let sort = {
 ascending: false
result.Sort(sort);
Hello @pshashipreetham,
Here is some code that should do what you want:
// if your dates are strings
let objects = [
 { date: "2023-04-19" },
 { date: "2023-04-20" },
 { date: "2023-04-21" },
let newestDate = new Date(
 Math.max.apply(
 null,
 objects.map(function (obj) {
 return Date.parse(obj.date);
result = newestDate.toDateString(); // Output: Fri Apr 21 2023
// if your dates are dates
let objects = [
 { date: new Date("2023-04-19T12:00:00Z") },
 { date: new Date("2023-04-20T12:00:00Z") },
 { date: new Date("2023-04-21T12:00:00Z") },
let newestDate = new Date(Math.max.apply(null, objects.map(function(obj) {
 return obj.date.getTime();
Hope this helps.
Jens
Hi @pshashipreetham
You can use the 'Sort' snippet to sort rows in InfoTable
/VR
pshashipreetham18-OpalAuthorAnswer
18-Opal
May 9, 2023
hi @Velkumar ,
let sort = {
 ascending: false
result.Sort(sort);
