Getting an error "Failed to return license click check" while opening Thingworx
rahulsoni6391
When I try to load ThingWorx Composer on my local machine, I get the Composer splash screen and then an error pops up:
As a result, I am unable to see composer and Thingworx data since this morning.
Do we have any solution for this error?
Rahul Soni
4 REPLIES 4
paic
(To:rahulsoni6391)
Hi Pai,
Thank you for providing the above link. It's very useful.
Could you answer the below question and suggest any link/article. It will be a great help from your end. Thank you!
  1. What causes the disk space to increase while using Thingworx? We can look at some of the default application/monitoring loggers and set them to a lower level than OOTB values (assuming logging is the reason ).
  2. Secondly if they have a TPR/CS which talks about different set of memory settings in Tomcat while using TWX; that would be helpful. For ex: if ‘x’ no. of developers are connected or ‘y’ no. of devices are connected and monitored, value of the memory settings to be set to ‘z’ MB.
Rahul Soni
paic
(To:rahulsoni6391)
Space on the server is taken up by:
1. the model
2. data persisted in the model
3. log files
4. files in FileRepositories
As for sizing of the JVM and Server, I believe there is ongoing work to get some sizing charts/guidance onto our Support portal.
Thanks for the above information!
Logged a TS case for it. May be. It will be resolved soon.
