When I try to load ThingWorx Composer on my local machine, I get the Composer splash screen and then an error pops up:
"Failed to return license click check"
As a result, I am unable to see composer and Thingworx data since this morning.
Do we have any solution for this error?
Rahul Soni
Check the following article: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS189387
Hi Pai,
Thank you for providing the above link. It's very useful.
Could you answer the below question and suggest any link/article. It will be a great help from your end. Thank you!
Rahul Soni
Space on the server is taken up by:
1. the model
2. data persisted in the model
3. log files
4. files in FileRepositories
As for sizing of the JVM and Server, I believe there is ongoing work to get some sizing charts/guidance onto our Support portal.
Thanks for the above information!
Logged a TS case for it. May be. It will be resolved soon.
