How to get the value centered in Value Display widget
  • August 8, 2022
  • 2 replies
  • 2525 views
There is no option  available that i can the height of the value centered do someone know another way to solve this ?
22-Sapphire I
August 8, 2022
Does the widget have a property called 'padding' you should be able to use that if it has it.
Sadly there is no property called padding in the value display .
Do you have an example code for me?
Community Manager
August 18, 2022
Hi @NN_10375125.
Which version of ThingWorx are you running?
--Sharon
