I just started looking into this, would really appreciate the guidance if anyone has already implemented or has any idea regarding how to go about this.
Hi @chaitanya have you already looked into using JDBC extension for ThingWorx? If not you could download it via the ThingWorx Marketplace JDBC Connector Extension
This'll allow you to create a JDBC template using the Athena JDBC driver
Hi @supandey ,
Thanks for the response.
I have already installed jdbc extension which helped me create a thing with autogenerated jdbc template.Configuration for the thing to connect athena has been done.
Then I created service containing SQL query which has been tested in Athena query editor. Currently I am facing an issue invoking this service.
Please find application log below:
2018-04-23 14:06:15.052+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: chaitanya] [S: ] [T: https-jsse-nio-8443-exec-3] [context: com.thingworx.webservices.context.HttpExecutionContext@4e2d91c9][message: Unable to Invoke Service hitAthena on athenaNew : Execute Update failed: java.sql.SQLException: [Simba][AthenaJDBC](100071) An error has been thrown from the AWS Athena client. Only one sql statement is allowed. Got: SELECT * FROM (select * from "db"."table";) T LIMIT 0]
@chaitanya if you already have a connection done to Athena I would recommend please closing this thread by accepting one of the threads replied under your question as accepted solution and then please open a new thread with your issue detailed with any error you might be encountering while invoking the service.
Looking forward to your new question.
sure, @supandey. Will create a new thread for invoking athena query editor with a service.
Thanks.
