I'm looking for thingworx java API that used external
bson21
Hell All.
I want to change thingworx field in external(exactly integrity lifecycle manager)
once integrity event happened, I will change thingworx field(such as true) for integrity event notification using thingworx java API.
Thank you in advance
BS
slangley
(To:bson21)
Hi @bson21.
If you are running ThingWorx Flow, there is an Integrity Lifecycle Manager that may be helpful (Flow itself may be helpful for what you want to achieve).  There is also a Data from Integrity Lifecycle Manager extension available on the Marketplace that you may want to check out.
--Sharon
raluca_edu
(To:bson21)
Could you please give us more details on this?
Raluca Edu
bson21
(To:raluca_edu)
I want to notify thingworx to get integrity type information when integrity type state chaged.
so when event(type state change) happened, using integrity event trigger, I want to make thingworx work.
in my investigation, the way thingworx can know integrity event(state change) is REST API.
so I need to know REST API usage using java script(method integrity can act when event happen)
slangley
(To:bson21)
Hi @bson21.
--Sharon
slangley
(To:slangley)
Hi @bson21.
Please let us know if you took a look at the Integrity Lifecycle Manager extensions mentioned in the previous post.  If that post has allowed you to solve your issue, please mark it as the Accepted Solution for the benefit of others on the community.
--Sharon
