I am repeatedly getting this error in application log while importing project. And the import is getting failed. It is pointing " [1,018] " for media, users, modeltags as well. How to rectify this?
1. Unable to process import: Unable to update user: [1,018] Data store unknown error: [Error occurred while accessing the model provider.]
2. [message: Unable to Invoke Service ImportSourceControlledEntities on SourceControlFunctions : Import Failed: Unable to update user: [1,018] Data store unknown error: [Error occurred while accessing the model provider.]]
when you observe message "Unable to update user: [1,018] Data store unknown error", you have to restart tomcat. After that, you can try to import files.
Latha
Latha
It is working now @vi1. But Importing project doesn't import DataTables right. But In my case it replaced all the DataTables(with data) to empty DataTables.
Now I have to export each and every DataTable through source control and import individually(from file, type-data) to get all the datas in DataTable.
1. How to stop replacing with empty dataTables?
2. Any other ways to export and import all datatables with all the datas?
You have to import Datatables data separately. In Import, select file->File type as "Data"->browse Datatable file ".twx". After selecting ".twx" file, click on import . You can see datatable entries after successful. You have to do one by one for all the datatables.
Latha
Okay Thanks. But while importing the project, the datatables(with datas) are getting replaced with empty datatables(zero datas). why? what is the solution for this ?
Datatable entries will not import when import the project. We have to do separately data after import all the entities. This is process.
Latha
We can import datatables first, then we can import project also right??
Hi @AP_9587236.
Can you provide more details of your import procedure? You shouldn't have to import each datatable individually.
One question we have is whether anything is changing in the datatable entity, such as the data shape, between the one you're overwriting vs. the one you're overwriting it with?
What version of ThingWorx are you running?
--Sharon
I am using thingworx 8.5.4.
There is no changes between the datatable entities of both server.
Right now iam exporting datatables separately using (to file, single data, datatables option) and import (from file, data, file repository, browse) to get the values in it. I am doing this export/import one by one for all datatables.
Hi @AP_9587236.
I recommend we open a case for this issue assuming you have a support contract. If so, please let me know if you would like me to open the case on your behalf. You'll need to provide your customer number and corporate email address (under private message).
--Sharon
Thanks ill let you know.
