Incomplete user extensions display if using Infotable
pjoly
hello
If I add an infotable (list of devices) in user extensions , most of extensions are no more displayed for each users :
UserExtensions definition :
user extensions displayed :
slangley
23-Emerald II
(To:slangley)
Hi @pjoly.
We tested under ThingWorx 8.4 but were unable to recreate the issue.  Since support for ThingWorx 7.4 has ended, you will need to upgrade to resolve the issue.
Please let us know if you have further questions.
--Sharon
5 REPLIES 5
slangley
23-Emerald II
(To:pjoly)
Hi @pjoly.
We have a few questions:
  • What version of ThingWorx are you running?
  • Do the extensions immediately disappear after adding the field or once you've added data to the infotable?
If you can provide more information, we will try to recreate it.
--Sharon
pjoly
(To:slangley)
  • What version of ThingWorx are you running?-> ThingWorx 7.4.9-b47
  • Do the extensions immediately disappear after adding the field or once you've added data to the infotable? -> immediately when I load the user without adding info
Regards
slangley
23-Emerald II
(To:slangley)
Hi @pjoly.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @pjoly.
Were you able to resolve your issue by upgrading ThingWorx?  If so, please mark the previous response as the Accepted Solution for the benefit of others with the same problem.  If you have found a different solution, please post it here and mark that as the Accepted Solution.
--Sharon
jfessard
(To:slangley)
hello
no I was not able to solve this issue and I cannot offer to upgrade to 8.4 now as it is so time consuming to upgrade !
