hello
If I add an infotable (list of devices) in user extensions , most of extensions are no more displayed for each users :
UserExtensions definition :
user extensions displayed :
Hi @pjoly.
We tested under ThingWorx 8.4 but were unable to recreate the issue. Since support for ThingWorx 7.4 has ended, you will need to upgrade to resolve the issue.
Please let us know if you have further questions.
--Sharon
Hi @pjoly.
We have a few questions:
If you can provide more information, we will try to recreate it.
--Sharon
Regards
Hi @pjoly.
--Sharon
Hi @pjoly.
Were you able to resolve your issue by upgrading ThingWorx? If so, please mark the previous response as the Accepted Solution for the benefit of others with the same problem. If you have found a different solution, please post it here and mark that as the Accepted Solution.
--Sharon
hello
no I was not able to solve this issue and I cannot offer to upgrade to 8.4 now as it is so time consuming to upgrade !
