I've removed the plugin extension, why does the plugin still exist?
and if that does not help maybe the issue is just with browser cache. try if it still appears in a private tab.
also check in installed extensions that it actually was deleted as you expect.
The version is 9.2.3,Please help me
Yeah, you're right. Thanks!
Yes clearing the browser cache did the trick!
how annoying!
Thank you, but it's a bit of a pain in the ass for me.
That's great to heat. Could you share what exactly did resolve your issue now?
