I have recently imported the Mail Server Extension (v3.4) in to Thingworx v9.
Configuration of the inherited Thing is:
SMTP Server name configured, SMTP Server Port 25, no authentication
When manually invoking the SendMessage Service I get the following error message:
Unable to Invoke Service SendMessage on MailServerThing : Couldn't connect to host, port: localhost, 80; timeout 30000
This says to me that it's still trying to connect to SMTP server on the local machine through port 80, despite the configuration.
Any ideas?
Update.
After installing the latest version, restarting the Server cleared the error above.
OK, so I upgraded the extension to v3.6 and am now getting.
ErrorCode(3592ead1-52d2-4fc4-b846-e66318a8b506), Cause(null), Reason(Access was attempted on a null reference variable.), Possible Resolutions(Remove the reference to the null variable within your extension code.)
Hi @DKinlough ,
I have gone through the same problem. Looks like the old version is not working anymore on TW 9.0 because the initialization method has a different signature.
Before TW 9.0:
protected void initializeThing()
From TW 9.0+:
protected void initializeThing(ContextType contextType) throws Exception {
I am attaching the updated extension but it is not covered by any license and it's not official.
Please have a look to the official extension shared in the PTC support website on the download software page for TW 9:
https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=TWX
in the group "ThingWorx Mail Extension".
Hi @DKinlough.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
Update.
