Mail Server couldn't connect. Not getting configuration?
DKinlough
6-Contributor
I have recently imported the Mail Server Extension (v3.4) in to Thingworx v9.
Configuration of the inherited Thing is:
SMTP Server name configured, SMTP Server Port 25, no authentication
When manually invoking the SendMessage Service I get the following error message:
Unable to Invoke Service SendMessage on MailServerThing : Couldn't connect to host, port: localhost, 80; timeout 30000
This says to me that it's still trying to connect to SMTP server on the local machine through port 80, despite the configuration.
Any ideas?
DKinlough
6-Contributor
(To:slangley)
Update.
After installing the latest version, restarting the Server cleared the error above.
DKinlough
6-Contributor
(To:DKinlough)
OK, so I upgraded the extension to v3.6 and am now getting.
ErrorCode(3592ead1-52d2-4fc4-b846-e66318a8b506), Cause(null), Reason(Access was attempted on a null reference variable.), Possible Resolutions(Remove the reference to the null variable within your extension code.)
rvecchiato
(To:DKinlough)
Hi @DKinlough ,
I have gone through the same problem. Looks like the old version is not working anymore on TW 9.0 because the initialization method has a different signature.
Before TW 9.0:
                        protected void initializeThing()
From TW 9.0+:
                        protected void initializeThing(ContextType contextType) throws Exception {
I am attaching the updated extension but it is not covered by any license and it's not official.
rvecchiato
(To:rvecchiato)
Please have a look to the official extension shared in the PTC support website on the download software page for TW 9:
https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=TWX
in the group "ThingWorx Mail Extension".
slangley
(To:rvecchiato)
Hi @DKinlough.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
DKinlough
6-Contributor
(To:slangley)
Update.
