Model deployment failed on connector TW.AnalysisServices.ThingPredictorConnector
darcudarcu
I have the ThingWorx 8.1.2-b51, it is not a trial or student license.
I can upload datasets and create models but at the moment I cannot publish them. I get the error: Model deployment failed on connector TW.AnalysisServices.ThingPredictorConnector.
I have tried to change the predictive-standalone.yml and redeploy the ThingPredictor JAR file from the command line.
In command line (running the JAR) I get warnings like:
log4j: WARN No appenders could be found for logger.
log4j:WARN Please initialize the log4j system properly.
Cannot resolve place holder for ${microservice.server}
And different warnings about varaibles (ex: data.service.url.prefix) being set twice.
I believe there was a previous installation of the PredictorConnector, maybe uninstall the previous one might solve the problem? How can I do that?
Kind regards.
cmorfin
(To:darcudarcu)
Hi @darcudarcu
Could you please do the following:
1) restore the original predictive-standalone.yml, so that there is no more the modification you did.
2) edit system-environment-variable.properties file and add the following lines:
working.directory= /C:/INDEFF/WORKFILES/MMAR/thingpredictor
analysis-manager-uri=<Your ThingWorx URI Here>
analysis-manager-appkey=<YOUR Appkey Here>
predictive.http.port=9090
predictive.admin.port=9091
microservices.server=localhost
Note 1:  for analysis-manager-uri you need to have the url to the web socket endpoint, that is for example
ws://123.123.123.45:80/Thingworx/WS
The /WS is important (and missing in your current yml file)
Note 2: you could start by just modifying your current yml file and add the WS at the end of uri.
If it does not work, do the above. It is much cleaner to only update the system-environment-variable.properties file and easier too.
Hope this helps
Christophe
11 REPLIES 11
cmorfin
(To:darcudarcu)
Hi @darcudarcu
Is there any chance you could use a newer version ?
Release 8.1 has reached its end of life last year (see https://support.ptc.com/cs/product_calendar/PTC_Product_Calendar.htm#RANGE!A529)
Christophe
Hi @cmorfin ,
if that is the only way to solve the issue I will take that possibility into account.
Are there some work-arounds to avoid (at least temporarily) the upgrade?
Regards
cmorfin
(To:darcudarcu)
Hi @darcudarcu
Usually those error were due to config issues. So likely problem in properties or yml file.
You can upload the following:
- system-environment.properties file
- predictive-standalone.yml
- the exact command you use to start ThingPredictor
we'll see if we see something obvious there, otherwise the upgrade will probably be needed.
Kind regards
Christophe
Hi @cmorfin ,
the command string is:
java "-Dvariables.file=file:///C:/xxx/WORKFILES/WVER/ThingWorx-Analytics-ThingPredictor/system-environment-variable.properties" -jar thingpredictor.jar server predictive-standalone.yml
The files are converted to .txt because of uploads issues, normally they have the standard extension.
cmorfin
(To:darcudarcu)
Hi @darcudarcu
Can you add the following line in your system-environment-variable.properties file:
Then start again the ThingPredictor agent.
Kind regards
Christophe
Hi @cmorfin ,
it fails to connect to the EndPoint (Error from: Command Prompt). Then I guess I have to try to Upgrade...
Are my things and Mashups at risk if I upgrade?
cmorfin
(To:darcudarcu)
Hi @darcudarcu
Could you copy the content of the ThingPredictor log into a file and upload it here ?
Christophe
Hi @cmorfin ,
hereby there is the log.  At the beginning there are different issues than in the end, since afterwards I modified the system-environment-variable file.
cmorfin
(To:darcudarcu)
Hi @darcudarcu
Hope this helps
Christophe
Hi @cmorfin ,
I deleted all the previous folder containing predictor stuff and I followed step 1 and 2.
It worked and I published the models successfully.
However, trying to test the models I encountered two further problems.
1) I am not allowed to fill-in values in Input Data Row Values.
2) I can fill Input Data Row Values but Analysis Job fails.
ApplicationLog:
Job was not found in runningJobs, could cause processing to stop
No results to map
Job not found for update: 601a7b8a-7331-4d45-8e68-ae97d6c063c5 Dynamic deployment completion event is not dispatched
AnalysisJob-->Results-->ImportantFields or predictiveScore--> error message: No parent row exists for the selected structure, loading the closest available parent.
Should I open a new thread for this and accept as valid answer the previous one?
cmorfin
(To:darcudarcu)
Hi @darcudarcu
Yes I think it is best to open a new thread so others can find the resolution quickly based on the description of this thread.
For the new thread, it can be useful if you add some screenshots of the Analysis model and event configuration (including input and result mapping).
Also can you clarify the 2 points:
because in step 1 you wrote you can't fill in value, but in step 2, you wrote you can ... so I am a bit confused.
Also some screenshot can be useful to understand why you can't fill in value.
Christophe
