Multiple Routes in Google Maps Widget
drieder
Hello everyone,
I would like to show multiple different Routes in one Google Maps Widget.
So far when I pass an Infotable with the locations, it will draw a line between all locations in the order as they appear in the table (of course!)
Is there a way to somehow pass either multiple Infotables (where each contains a route) or somehow prevent some lines from drawing?
Thank you in advance for your help.
Best Regards,
Dominik
PaiChung
22-Sapphire I
(To:drieder)
The Map right now supports
Planned Route and Actual Route so you can show at minimum two.
I forget if you can use the regular datapoints and draw a line between the two or not.
each of these would have to be an InfoTable of points in your data set so InfoTables inside of InfoTables
You can do many more regions, but the drawback is that the regions always draw a closing line from end to beginning of the series.
PaiChung
22-Sapphire I
(To:drieder)
slangley
(To:PaiChung)
Hi @drieder.
If the response provided by @PaiChung answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
