I'm trying to set up a connection to a MySQL database that I have. I've installed the JDBC Connector extension from the marketplace and that gave me the JdbcCreator and the JDBCExtentionCreator.
Following a PTC document it says to create a new thing and select MySqlServer as the thing template. However, I am unable to see a MySqlServer template.
Any ideas? Have I missed something?
Please confirm you followed the steps:
Hope it helps,
Raluca Edu
Thank you for your response.
JDBC file is not able to choose and upload.
Could you attach a screenshot?
Raluca Edu
I herewith attached the screen shots for your reference.
Thanks for screenshots. On my side the upload of mysql connector worked well (zip file) and I was able to download the extension for mysql JDBC.
After downloading the extension, I have open Composer and imported it with success.
I will attach it here, maybe it will help you.
Raluca Edu
Thank you for sharing that file , but that too is not working for me.
I also checked with my colleague Thingworx, for him also it's not working.
Probably you need to generate it from your environment.
I have used the connector from the attachment.
Try to generate extension with that connector.
Raluca Edu
Hi @jaganprasanth.
If Raluca's suggestions allowed you to solve your issue, please mark the appropriate reply as the Accepted Solution for the benefit of others on the community.
--Sharon
