I'm having trouble writing a simple loop. I have arrays with three columns.
The columns are Group , Date and Value. The group is the same for all rows.
The same date occurs many times - and I need to sum up the values for the same dates and write them into a new table.
The code I can write in pyhon and VBA - here I can not get around the limitations of JS in ThingWorx
Considering Array means InfoTable on the Thingworx side
I have sample dummy data
Below code to calculate each day sales
var rawData = me.dummy;
// Create Infotable to store data
let params3 = {
infoTableName: undefined /* STRING {"defaultValue":"InfoTable"} */
// result: INFOTABLE
let result = Resources["InfoTableFunctions"].CreateInfoTable(params3);
// Add fields to store total and date value
result.AddField({
"name": "Total",
"baseType": "INTEGER"
result.AddField({
"name": "Date",
"baseType": "DATETIME"
// Get Distinct / Unique Value of Date. Removes duplicate dates from Infotable
// Used to get count for each day
let params = {
t: rawData /* INFOTABLE */ ,
columns: "Date" /* STRING */
let distinctDateValues = Resources["InfoTableFunctions"].Distinct(params);
// Iterate Over distinct date values
for (let i = 0; i < distinctDateValues.length; i++) {
// Create query to filter data based on date
let query = {
"filters": {
"type": "EQ",
"fieldName": "Date",
"value": distinctDateValues[i]["Date"] // Date is keyword in JS. Always add suffix / prefix to date variable
let params = {
query: query /* QUERY */
var filteredValue = Resources["InfoTableFunctions"].Query(params);
// Calculate sum of each day
let params2 = {
t: filteredValue /* INFOTABLE */ ,
columns: "Value" /* STRING */ ,
aggregates: "SUM" /* STRING */ ,
groupByColumns: undefined /* STRING */
var totalForDay = Resources["InfoTableFunctions"].Aggregate(params2);
// Add calculated value to new infotable
result.AddRow({
"Total": totalForDay.SUM_Value,
"Date": distinctDateValues[i]["Date"]
// Additional : sort column by date
let params4 = {
sortColumn: "Date" /* STRING */,
t: result /* INFOTABLE */,
ascending: false /* BOOLEAN {"defaultValue":true} */
result = Resources["InfoTableFunctions"].Sort(params4);
Result :
Or
If you want the total directly from Infotable, just mention groupByColumns as "Date"
let params2 = {
t: me.dummy /* INFOTABLE */ ,
groupByColumns: "Date" /* STRING */
var result = Resources["InfoTableFunctions"].Aggregate(params2);
Please do post here if you have any queries
/VR
let params3 = {
result.AddField({
"name": "Total",
result.AddField({
"name": "Date",
let params = {
let query = {
"filters": {
"type": "EQ",
let params = {
let params2 = {
result.AddRow({
let params4 = {
Result :
Or
let params2 = {
/VR
Hi @Michael_Dezet ,
As continue of @Velkumar post, If you are considering direct array in your case means. Please find the below code,
var inputArray = [
{ Group: 'A', Date: '2023-08-29', Value: 10 },
{ Group: 'A', Date: '2023-08-29', Value: 20 },
{ Group: 'A', Date: '2023-08-30', Value: 15 },
{ Group: 'A', Date: '2023-08-30', Value: 25 },
{ Group: 'A', Date: '2023-09-30', Value: 25 },
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(PTC.SimpleLoop.DS)
let summedTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
infoTableName: "InfoTable",
dataShapeName: "PTC.SimpleLoop.DS"
var summedValues = {};
for (var i = 0; i < inputArray.length; i++) {
var row = inputArray[i];
var group = row.Group;
var date = row.Date;
var value = row.Value;
var key = group + "_" + date;
if (!summedValues[key]) {
summedValues[key] = { Group: group, Date: date, Value: value };
} else {
summedValues[key].Value += value;
for (var key in summedValues) {
var summedRow = summedValues[key];
// PTC.SimpleLoop.DS entry object
let newEntry = {
Group: summedRow.Group, // STRING
Date: summedRow.Date, // DATETIME
Value: summedRow.Value // NUMBER
summedTable.AddRow(summedRow);
result = summedTable;
Output as below
Thanks & Regards,
Arun C
