Hi @Michael_Dezet
Considering Array means InfoTable on the Thingworx side
I have sample dummy data
Below code to calculate each day sales
var rawData = me.dummy;
// Create Infotable to store data
let params3 = {
infoTableName: undefined /* STRING {"defaultValue":"InfoTable"} */
// result: INFOTABLE
let result = Resources["InfoTableFunctions"].CreateInfoTable(params3);
// Add fields to store total and date value
result.AddField({
"name": "Total",
"baseType": "INTEGER"
result.AddField({
"name": "Date",
"baseType": "DATETIME"
// Get Distinct / Unique Value of Date. Removes duplicate dates from Infotable
// Used to get count for each day
let params = {
t: rawData /* INFOTABLE */ ,
columns: "Date" /* STRING */
let distinctDateValues = Resources["InfoTableFunctions"].Distinct(params);
// Iterate Over distinct date values
for (let i = 0; i < distinctDateValues.length; i++) {
// Create query to filter data based on date
let query = {
"filters": {
"type": "EQ",
"fieldName": "Date",
"value": distinctDateValues[i]["Date"] // Date is keyword in JS. Always add suffix / prefix to date variable
let params = {
query: query /* QUERY */
var filteredValue = Resources["InfoTableFunctions"].Query(params);
// Calculate sum of each day
let params2 = {
t: filteredValue /* INFOTABLE */ ,
columns: "Value" /* STRING */ ,
aggregates: "SUM" /* STRING */ ,
groupByColumns: undefined /* STRING */
var totalForDay = Resources["InfoTableFunctions"].Aggregate(params2);
// Add calculated value to new infotable
result.AddRow({
"Total": totalForDay.SUM_Value,
"Date": distinctDateValues[i]["Date"]
// Additional : sort column by date
let params4 = {
sortColumn: "Date" /* STRING */,
t: result /* INFOTABLE */,
ascending: false /* BOOLEAN {"defaultValue":true} */
result = Resources["InfoTableFunctions"].Sort(params4);
Result :
Or
If you want the total directly from Infotable, just mention groupByColumns as "Date"
let params2 = {
t: me.dummy /* INFOTABLE */ ,
groupByColumns: "Date" /* STRING */
var result = Resources["InfoTableFunctions"].Aggregate(params2);
Please do post here if you have any queries
/VR
