The message you are trying to access is permanently deleted.
I have setup the Postgres DB in Red Hat Linux Machine. I have also followed all steps as mentioned in the pdf : http://support.ptc.com/WCMS/files/170230/en/Installing_ThingWorx_7.1_1.2.pdf
But while running the TW Postgres DB setup script mentioned in step 14, I am getting syntax errors.
Please let me know how to resolve the issue. The Thingworx, ThingworxPostgresqlStorage and ThingworxPlatform have been created in the same location as mentioned in the document
Running the following two commands from postgres bin directory showed that there were some rpms from 8.4 postgres installation in the OS path. Removing them resolved the issue.
./psql postgres
\set
\q
psql -q -h localhost -U twadmin -p 5432 -v database=thingworx -v tablespace=thingworx -v tablespace_location=/app/navigate/ThingworxPostgresqlStorage -v username=twadmin
\set
What are the actual errors?
I am getting syntax errors - syntax error at or near ‘:’ when i am running the script for all cases like creating tablespaces, database,etc.
To me that sounds like there is an error in one of the files you had to customize.
I am getting the same error. I have customized any thing and running the installer as is. Any idea how to proceed?
Sorry. I meant I have not customized anything.
Was the issue resolved for you?
./psql postgres
\set
\q
\set
