Thingworx HA
SOLVED
Re: Thingworx HA
I have re verified config file and followed zookeeper configuration document.
still not able to solve.Below are followed in Zookeeper system .
OS: Windows server 2012 R2
1. Installed Java JDK 8
2. Updated java heap size as -Xmx6000m(RAM size is 8GB)
3. Zookeeper deployment 3.5.5-bin
4. Added JAVA_HOME, ZOOKEEPER_HOME path in Environment variable
5. Updated zoo.cfg file and created myid file . Refer the attached screenshots.Also, attached zoo.cfg file.
Could you please help on Zookeeper server issue. I am expecting directory structure issue where i am keeping myid file. I have tried all the possibilities.
Latha
Re: Thingworx HA
Try to use double slashes in the paths in your zoo.cfg, e.g. "c:\\zookeeper\\data"
/ Constantine
Re: Thingworx HA
Yes, I have tried . same issue after giving the double slash.
Latha
Re: Thingworx HA
It's very strange, because I've just tried the same, and it works fine for me -- Zookeeper starts. Maybe try one more thing -- copy this "myid" file into the same "c:\zookeeper\apache-zookeeper-3.5.5-bin\conf" directory, and try this as a zoo.cfg:
tickTime=2000
initLimit=10
syncLimit=5
dataDir=c:\\zookeeper\\apache-zookeeper-3.5.5-bin\\conf
clientPort=2181
maxClientCnxns=60
server.1=127.0.0.1:2888:3888
server.2=127.0.0.1:2888:3888
server.3=127.0.0.1:2888:38888
If that doesn't work, then I don't know what to do and would share @slangley suggestion to ask it on some Zookeeper specialized resource or StackOverflow.
/ Constantine
Re: Thingworx HA
I've just understood -- your myid has ".txt" extension! Remove this extension, it should be called just "myid", then it will work. Keep double slashes though.
/ Constantine
Highlighted
Re: Thingworx HA
Thank you for suggestions. Now solved myid file issue after remove the extension.
Thank you very much for helping.
