Using Thingworx i want create barchart with multiple colors,we are having multiple catagories
bhavya
7-Bedrock
I am having multiple catagories with different data for each data i want to show multiple colors in one bar. Can someone help me out. Is there any extension available? Please find attached screenshot
wcui
(To:bhavya)
Hi Bhavya, I think below article can better answer your question.
Please add Bar Chart Widget in your mashup, then check article Resolution -> Image3, set widget property SeriesDisplay to "100% Stacked".
Please also read article for other property settings such as NumberOfSeries, X-Axis-Field, DataFieldx.
https://www.ptc.com/en/support/article/CS340527
6 REPLIES 6
Hi @bhavya
Following post should help.
Sachin
Thank you for quick response @SachinSharma I will check and get back to u
wcui
(To:bhavya)
bhavya
7-Bedrock
(To:wcui)
Its worked thank you @wcui
wcui
(To:bhavya)
hi Bhavya, you need to sign in with PTC Account to view this article.
