Breadcrumbs issue
SR_9679028
9-Granite
Breadcrumbs issue
I am  using Breadcrumbs widget in a responsive layout, In runtime, if I use 2 links the last link in the breadcrumbs not shown fully. If use more than 2 or 3 links it showing correctly. find the image for reference. Please any one give a solution ASAP.
Thanks.
Hi @SR_9679028
I am unable to replicate the behavior. Can you please confirm the Thingworx version you are using?
Sachin
Thingworx9.1
@SR_9679028
I tried on 9.1 and I am still unable to reproduce the behavior, refer below screenshot.
Can you create a test mashup and if you are able to replicate the issue on it then attach all the entities here. I will import them on my instance and check the behavior.
Sachin
