What is Web Design Kit in ThingWorx?
RK_0705
Hi Team,
Just came across some links on Web Design Kit but unable to understand.
Can anybody help me in understanding the Web design kit as well as its purpose.
Also, how to use it?
Thanks in advance.
4 REPLIES 4
slangley
(To:RK_0705)
Hi @RK_0705.
Can you provide the links you are referring to so I can check further into your inquiry?
Thanks.
--Sharon
slangley
(To:slangley)
Hi @RK_0705
I think we found the Web Design Kit you were referring to.  Is this the one?
If so, I will try to find someone to answer your question.
--Sharon
RK_0705
(To:slangley)
@slangley
Yes.. this is the one I am referring to.
mgoel
(To:RK_0705)
Hi @RK_0705
Web design Toolkit is a prebuilt mashup with a good and attractive UI. Which you can use in your projects/applications.
https://github.com/ptc-iot-sharing/WebDesignKit  Check readme.md file at github, usage, configuration and description everything has already briefed there.
Did you try to import it. In case of any issue you can reply me back.
Mohit
