Y-Axis values over bar
ketanaga
Hi
I have imported CharWidget - v3.0.3 extension from the marketplace, which allows the label chart to view Y-Axis values on the bar using ShowValues option under properties, but I don't see such option listed in the properties section. Is there a way I can achieve the following.
Thanks and Regards
Ketan Agarwal
6 REPLIES 6
ketanaga
(To:ketanaga)
Hi
Any update on the following request?
slangley
23-Emerald II
(To:ketanaga)
Hi @ketanaga.
Which version of the platform are you running?  In the latest version of the Custom Chart widget (which is now available on the support site under the relevant ThingWorx version), the value does display on hover.  Not sure this is what you were looking for.
Perhaps I'm overlooking it, but I was not able to find the property you indicated in the documentation for the version you're running.  You can make a suggestion for this feature on the ThingWorx Ideas page.
--Sharon
ketanaga
(To:slangley)
Hi
I am currently running TWX 8.5 and imported v-3.03 of the chart widget extension. The requirement here is to have the y-axis value to be displayed on top of each bar rather than hovering over it.
Regards
slangley
23-Emerald II
(To:slangley)
Hi @ketanaga.
I would first download the latest version of the Custom Charts widget extension which is available on the Support site:
Please see if this one may get you closer to what you are needing.
--Sharon
ketanaga
(To:slangley)
Hi @slangley
I was able to achieve the same using a Bar-chart but still the requirement still does not fulfill for scenarios when the chart has dual y-axis.
Regards
Ketan Agarwal
slangley
23-Emerald II
(To:ketanaga)
Hi @ketanaga
I recommend posting a request on the ThingWorx Ideas board.  Doing so will allow others to vote for it which will increase its chances of being considered for a future release.
--Sharon
